Define Weld Evaluation Point Properties
Use the Points tool to define the properties of the weld lines considered in the evaluation.
Click the Points tool.
The Evaluation Points dialog opens. - Select a weld line.
Select a method for calculating evaluation distance.
Option Description Auto Evaluation distance is calculated internally based on the evaluation distance(s) and weld width. Manual The tool uses the values you specify to identify the location. -
Edit the general parameters and the location parameters for the weld by
selecting options from the drop-down menus or entering values in the text
boxes.
Note: The properties available in each table are updated according to the specification selected.Each point is defined at the evaluation distance specified in the General table and is measured from the weld segment centroid.
- Optional:
Manually select weld lines to evaluate by
activating/deactivating the Evaluate checkboxes.
Tip: Use the selection tools in the top-left of the dialog to quickly select all, none, or reverse your selection of weld lines.
- Optional:
Click
to import a Weld Property file
(.xml) containing the data of all the classification
parameters with respect to each weld line.
- Optional:
Click
to save the data of all the classification
Exported files can be used in a later run when defining a weld specification.
An additional evaluation point will be added for a weld end. Its evaluation distance will be measured from the free end of the weld segment. The weldend will be listed in the location table of points context and will be evaluated when the preference option Enable Weld End Evaluation is activated.Figure 3.
- Optional:
Apply weld template.
- Select the weld line(s) of the same type.
- For Weld Category, select a weld template.
Note:- The template names for the weld type are listed from the weld template .xml saved in the Weld template directory.
- The default templates listed for each regulation are placed here: C:\Program Files\Altair\<installation directory>\hwdesktop\utility\HWFatigue\WeldCertification\WCD\5_regulations\<regulation>\weld_configurations. These templates are in .csv format and are part of the standard installation.
- Refer to Weld Templates for more information about weld templates.
