Create Materials
Create new materials for use with the base material calculation.
Click the tool.
The Assign Material dialog opens. - Click the My Material tab.
Click
to add a material.
- Optional: Change the name of the material.
Using the SN and Other tabs, set the material properties.
The current defaults are specific to steel and will be extended to other materials in future releases.
- Click Save.
Right-click on a material and select Add to Assign Material
List from the context menu.
The created material is now available for selection in the Assign Material Data tab.
