Load Map
The event setup section is defined within this tag.
The load map section is defined
within:
<LoadMap>
</LoadMap>| Element Tag | Valid Values | Comment |
<LoadMapFile> |
Valid file path | Applicable for Duty cyle (.dcy)
file Applicable for LoadMap (.xml) file |
<Channel> |
<tabfat> |
Mandatory |
<FatigeEvents> |
Mandatory |
<Fatseq> |
<Fatevnt> |
Mandatory |
