Acoustic Cavity meshing generates a fluid volume mesh used to calculate the acoustic
modes (or standing waves) inside the air spaces of a vehicle or similarly enclosed
structural model.
Acoustic cavity meshing is primarily used by Noise, Vibration, and Handling (NVH)
engineers to design quieter interiors.Figure 1.
Acoustic cavity meshing can be a CPU-intensive process, especially with fine and/or
complex meshes, but this can be offset by additional CPU cores. The Acoustic Cavity
Mesher is multithreaded to take advantage of multi-core environments.
