Add/Edit Bookmark Dialog
Use this dialog to add or edit a bookmark comment. This dialog displays when you select Bookmark on the Report View Ribbon.
The following table describes the options available for this dialog.
Field |
Description |
Comment Field |
Enter the comment you want to annotate the bookmark with here. |
Show when adding |
Select if you want the Bookmark Comment dialog to display whenever you add a bookmark. If you don't want the dialog to display in the future, you may clear this checkbox. To access this dialog after clearing this checkbox, right-click on a bookmarked line and select Edit Bookmark Comment from the context menu. |
OK |
Saves the current settings and closes the dialog. |
Cancel |
Cancels any changes and closes the dialog. |
Help |
Displays this help topic. |
