The Cloud Browser
The standard cloud browser allows you to import data from and save/export data to cloud-based sources. An example cloud browser for Amazon S3 is shown below.
Depending on the cloud source, you may need to:
      Select a container/server.
      Find the folder and data source you wish to open. You may need to drill down several folders before you find your data source
      Select the data source and then click OK.
Note:
If you wish to open a data source from the following storage systems:
      HTTP
      FTP
      Microsoft Azure
      Amazon S3
      Oracle Cloud Infrastructure
      Google Cloud Storage
      IBM Cognos Analytics
      Tableau Server
      Altair Monarch Server Library
you must first set access credentials for these applications in the Server tab of the Application Default Settings dialog.
