Clipboard Options
Use this window to specify how Monarch Classic copies data from a document to the system clipboard.
To access this window select Options from the Home ribbon, then select Clipboard from the Options Window ribbon.
The table below describes the available options.
Field |
Description |
Include field names as the first row |
Use this setting to export the Table window field names (or Summary window column titles) when exporting data to the Clipboard. |
Text Format |
Pad each field with one extra space |
Adds a space after a fixed-length text field. |
