Column List
Allows you to:
Edit column information:
Rename a column
Change the field type (text, date/time, numeric)
Set the format for date/time or numeric fields
Reposition (rearrange) columns within a table
Hide/unhide individual or all columns
Adjust the column width
Set the text alignment (left, center, right)
Set name casing (proper case, upper case, lower case)
Apply selected format to all other fields of the same type (for numeric and date/time fields)
View the number of columns included in the table and the macros applied to them
Related Links
