Connector Dialog Error Messages
These are error messages you may encounter when using connectors.
Error message in Connector UI: Syntax Error
Error message in Log file: [Altair][ODBC SQL Server Wire Protocol driver][Microsoft SQL Server]Incorrect syntax near [QUERYSTMT]
When connecting to ODBC DSN using "Altair SQL Server Wire Protocol" driver, user may encounter this error when loading a list of tables.
Possible Solutions
Enable "Enable Quoted Identifiers" in ODBC settings:
Add "EQI=1" in the Connection Settings string:
