Connector Dialog for Altair Monarch Report Warehouse
Enter values into the dialog to connect to and fetch data from your Altair Monarch Report Warehouse data source.
Options
| Field | Description |
| Monarch Server Client URL | URL used to connect to Monarch Server. |
| Username | A valid Username for Monarch Server. |
| Password | A valid Password required to log-on the data source. This password must match the User ID above. |
| Connect | Click this button after you have specified the Server, Username, and Password. After a successful connection, you select a report. |
| Document Type Group | Select a Document Type Group from the drop-down. The list depends on the access rights defined for the current user. |
| Select a Document Type | Select a Document Type from the drop-down. The list depends on the access rights defined for the current user, as well as the Document Type Group initially selected. |
| Model | Select the Model you want to use for the document. |
| Report Date | Allows you to set a Date Range. Only documents that fall within this date range will be returned. |
| Report | Displays a list of reports that meet the criteria defined above. Highlight the reports that you want to use. |
| View | Select the report view that you want to use. |
| Summary Name | Select the Summary that you want to be applied. The list displayed here depends on the Model and View that you selected above. |
