Connector Dialog for IBM Cloudant
Enter values into the dialog box to connect and fetch data from your IBM Cloudant data source.
Options
| Field | Description |
| Cloudant Account or URL | Enter one of the following:
| Connect to a Specific Database | Check this box if you are logging into a specific database. Then, enter the name of the database that you will be logging on to. Otherwise, you can leave this blank. |
| Username | A valid Username required to log-on to Cloudant. |
| Password | A valid Password required to log-on to Cloudant. This password must match the Username above. |
| Login | Click on this button to log-on to Cloudant. This assumes that the Account/URL, Database, Username, and Password have been entered correctly. A message box is displayed confirming if the login was successful. |
| Database | Select the database you will connect to. |
| Source Type | Select the Source Type. Corresponding sections will be enabled depending on the source type you select. |
| Source Type = View | If you select Source Type = View, configure how you wish documents to be returned from the view:
| Source Type = Search Index | If you select Source Type = Index, configure how you wish documents to be returned:
| Preview Data | Click to fetch data using the credentials and criteria you have specified. 10 records are displayed to allow you to verify that you are selecting the correct data. |
| OK/CANCEL | Select OK to establish the connection and fetch data or Cancel to close the dialog. The state of the OK and PREVIEW buttons provides a handy status about the state of your connection:
