Connector Dialog for Google Sheets
NOTE: The Google Sheets API only supports spreadsheets created within Google Sheets itself and does not support Excel files imported into the system.
Enter values into the dialog box to connect and fetch data from your Google Sheets data source. Select a specific tab to display specific options.
On the connector dialog, hover your mouse over the field name to display a description or help about that field.
| Connection Tab | |
Fill out the fields below to initiate a successful connection. Bold fields are required.
Field |
Description |
Authentication Method |
Determines the authentication method to be used during the course of the session. Select the method from the drop-down list:
Key File Path |
This is a required field if you selected Service Account as the Authentication Method. Enter the Service Aoount key file (in JSON format) containing the credentials. |
Client ID |
Enter the client ID key for your application when authenticating to REST endpoints with OAuth 2.0 enabled Note: In some cases, the value of this option is the same as your user name or authenticating address. In others, this value is supplied with your Client Secret. If you experience and authentication error, verify that you are using the correct value. |
Client Secret |
Enter the client secret for your application when authenticating to REST endpoints with OAuth 2.0 enabled. Important: The client secret is a confidential value used to authenticate the application to the service. To prevent unauthorized access, this value must be securely maintained. |
Scope |
Enter a space-delimited list of OAuth scopes that limit the permissions granted by an access token at the time of connection Default value is: https://www.googleapis.com/auth/spreadsheets https://www.googleapis.com/auth/drive https://www.googleapis.com/auth/drive.file https://www.googleapis.com/auth/drive.readonly |
FileQuery |
Enter the query string to filter the files to return. To search for a specific set of files or folders, use the query string q field with the files.list method to filter the files to return by combining one or more search terms. A query string contains the following three parts: query_term operator values Where:
Example The following query string filters the search to only return folders by setting the MIME type: Refer to this page for more details. |
Range Column Start |
Required. Specifies the start column number of the range. |
Range Column End |
Required. Specifies the end column number of the range. |
Range Row Start |
Optional. Specifies the start row number of the range. If no value specified, row start will be set to 0. |
Range Row End |
Optional. Specifies the end row number of the range. If no value specified, row start will be set to 1000. |
First Row Is Headers |
Select True to convert the first row in the sheet to a column header. Default is True. |
Reset |
Select to True to reset the session. Default is False. |
Application Name |
Name of the application. Default value is Monarch Google Sheets |
| Tables and View Tab | |
Tables and Views |
Allows you to load, and then select, the tables from your database by manually selecting from a list. To load tables and views via search and select:
Note: If you wish to add a duplicate column, select this column from the Add a duplicate column drop-down list provided.
To select a column: Check the boxes beside the columns you want to use. If you want to use all columns check the Column box on the header.
To aggregate columns:
If the data returned are to be aggregated, check the Aggregate box on the header, then select the aggregation method you want to use for each column. The following aggregation methods are possible for each data type:
To filter columns:
If the data returned are to be filtered, check the Apply Filter on the header. Then, for each column, select a filter method from the filter drop down and then enter the filter value in the Filter Value box. Notes:
Preview Data |
Click to fetch data using the credentials and criteria you have specified. This allows you to confirm your connection, ensure you have connected to the correct table, check your query, and verify the information that will be loaded. Notes:
| Query Tab | |
Query |
Allows you to load, and then select, the tables from your database by entering a SQL Statement. If you already selected Tables and Views, this box is updated to show the corresponding SELECT * FROM TABLE query.
If you want to define the query, enter the SELECT, EXEC, and/or WITH statements to execute. Notes
Preview Data |
OK/CANCEL |
Select OK to establish the connection and fetch data or Cancel to close the dialog. The state of the OK and PREVIEW buttons provides a handy status about the state of your connection:
