Other Connection Options
Most Monarch Data Prep Studio connector dialog boxes provide a text box that allows you to enter additional connector options:
Notes:
      If you need multiple string connection options, separate these by a semi-colon. Use the form: Option1=[value];Option2=[value];
      You can only enter up to a maximum of 512 characters into this text box.
Options and valid values for specific connectors may be found here:
| Connector | Options and Values |
| Amazon EMR Hive | |
| Amazon Redshift | |
| Cassandra | |
| Cloudera CDH Hive | |
| Cloudera Impala | |
| DB2 | https://docs.progress.com/bundle/datadirect-ibm-db2-odbc-80/page/Connection-option-descriptions.html |
| Google BigQuery | |
| Hadoop Hive | |
| Hortonworks Hive | |
| HubSpot | |
| Informix | |
| MapR Hive | |
| MySQL | |
| NetSuite | https://docs.devart.com/odbc/netsuite/connection_options.htm |
| MongoDB | https://www.mongodb.com/docs/drivers/csharp/current/fundamentals/connection/connection-options/ |
| Oracle | https://docs.progress.com/bundle/datadirect-oracle-odbc-80/page/Connection-option-descriptions.html |
| PostgreSQL | |
| ServiceNow | |
| SharePoint | |
| Spark SQL | |
| SQL Azure | |
| SQL Server | |
| Sybase IQ | |
| Teradata |
