Create Export Dialog
This dialog allows you to create an export definition.
To access this dialog box, select Create Export on the Export View ribbon.
The table below describes the settings in this dialog.
Field |
Description |
File Name |
Enter the file name that will be used for export output. |
Source View |
Use this selector to select the source of the export. |
Export File Type |
Specify the export file type. Additional options need to be defined depending on the file type that you select. |
Run this Export |
Select this button if you want to immediately run the export after defining it. |
Add to Project |
Click this button if you want the export to be saved with the Project. |
Advance Options |
Select this button to define additional options. Options vary depending on the Export file type. |
When output files exist options |
Provides options for when a file of the specified name and type already exists in the export location. Select one of the following options:
