Customizing Summary Font and Background Colors
Monarch Classic enables you to customize the colors of summary fonts and backgrounds.
      Go to Summary Design.
      Select a Summary from the Summaries selector. The Summary's properties are displayed on the Summary Window.
      Do one of the following: -
          If you wish to view or edit all fields, select All Fields from the Summary Design ribbon.
          If you wish to view or edit just keys, items, or measures, select Keys, Items, or Measures respectively from the Summary Design ribbon.
      Select the Coloring tab.
Note:
      On the Measures Tab, you will have Coloring and Limits tab instead of Coloring tab.
