Customizing Time Interval Formatting Masks
Monarch Classic allows you to edit the time interval formatting masks.
Select Option from the Home Ribbon Quick display the Options Window.
Select Time Intervals to display the Time Intervals Options.
Select the Formatting sub-tab.
In the Interval list, select the Formatting Mask corresponding to the interval whose formatting mask you want to customize. Click the formatting mask button
to display the Formatting Mask drop-down. -
Customize the formatting mask by inserting the desired time intervals formatting macro(s) from the drop-down list, then click the Accept.
