Altair Monarch Server Library Options
Use this window to specify an Altair Monarch Server Library from which to access and save projects and models.
Security Options
| Field | Description |
| Location | Specifies the location of the Monarch Server Library from which you can open files and to which you can save models and projects |
| User | Identifies an authorized user of the library |
| Password | Specifies the password required to access the library |
| Single Sign-on | Uses single sign-on to access the Monarch Server Library |
| Update | Updates and saves the specified credentials |
| Set as default | Uses the specified server and credentials as the default setting for saving models and projects |
| Remove | Removes the specified credentials |
| Default Save Project and Save Model behavior | Specifies whether or not the Server library is to be used when saving projects and models.
