Editing/Revising Templates
When you accept a template, data is extracted from the spreadsheet and displayed on the Prepare Window:
You can work with the data at this point as you would with any table. However, you can still modify how the data is extracted by editing the templates.
Right-click on the table.
Select Edit in Worksheet Design from the context menu.
Edit the traps as needed.
