Editing Changes in Change History
You can modify some changes applied to tables and columns from the Change History panel.
The following example demonstrates how an applied filter is modified in Change History.
      Display the Change History List panel.
      Select the Edit icon beside the filter entry you want to review or edit.  The <Change Type> dialog box displays. In the example below, the Define Filter dialog displays because the change to be edited (as shown in the example above) is a filter definition.
      Use the options provided to modify the filter and then select OK.
