Editing Table Load Options
In the course of your data prep work, you may find that the table you selected from a set of tables in a Microsoft Access file does not contain the information you need. Monarch Data Prep Studio enables you to easily change this table via its Edit Load Option functionality. This functionality allows you to:
- Select a different table/worksheet from the source Access/Excess file
- Modify input options (e.g., delimiter, text qualifier, number of lines to skip) for delimited text files
- Modify input options (e.g., Excel import connector, named ranges, number of lines to skip) for Excel worksheets
- Modify input options (e.g., which row has column names, number of lines to skip) for HTML tables
Note: If load options for a data source with a missing/invalid password are to be modified, the correct password must be supplied before load options can be accessed. Otherwise, load options for this data source cannot be modified.
In the Prepare Window, click the drop-down arrow beside the Excel, CSV, HTML, or Access table of interest and then select Edit Load Options.
You can also:
Click Edit Load Options at the bottom of the Change History panel.
Click Load Options in the Column Information panel when a table is previewed.
Implement the changes necessary using the following dialogs and tables as guides:
FOR MICROSOFT ACCESS DATA SOURCES
Field
Table
Specifies which table in the Access file to load into the workspace.
FOR MICROSOFT EXCEL DATA SOURCES
Field
Sheet
Specifies the name of the sheet to load into the workspace.
Lines to skip
Specifies the number of rows to skip, starting from the first line, if these lines do not contain data.
First Row Has Column Names
When selected, indicates that the first row of the sheet includes the column names.
Ignore Blank Rows
When selected, instructs the application to ignore blank rows and load the table without these rows.
Import columns as Text
When selected, instructs the application to import all columns with the data type text regardless of the original data type.
Automatically sync columns with source data on load or refresh
When selected, instructs the application to sync the columns of the loaded table with the columns of the source table upon load or refresh.
This functionality is useful in instances where the columns in your source table change over time. Note that when this mode is applied, your Change History items may yield an error state if the columns the sync is applied to are renamed or deleted from the source file.
Input Connector
Specifies the connector type (i.e., Monarch Excel Table or Monarch ACE OLE DB (Legacy) to apply when the table is loaded.
Scan and Define Columns
When selected, instructs the application to return data types to their original values (as determined by the Monarch Excel Table connector).
This option is deactivated if the input connector is Monarch ACE OLE DB (Legacy) or Automatically sync columns with source data on load or refresh is selected.
Bulk Type Edit
Specifies a single ("bulk") data type to apply to all fields in your data source.
NOTE: Specific data types can be assigned to each of the columns in your Excel data source using the Type drop-down lists provided to the right of each column.
FOR HTML DATA SOURCES
Field
Lines to skip
Field
INPUT OPTIONS
Delimiter
Specifies the type of delimiter used to separate fields in a delimited text file. The most common delimiters are:
- Comma
- Tab
- Semicolon
- Space
- Pipe
If the delimiter you are looking for is not on this list (e.g., ^), simply type it into the field.
Lines to skip
Text Qualifier
Specifies the text qualifier used to mark the start and end of a column entry. The most common text qualifiers are:
- Double quote
- Single quote
- None
Rows to scan for columns
Specify how many rows to scan in your data source before Monarch Data Prep Studio decides on a data type for the column.
Note that setting this number to a very high value may negatively impact the application's load performance depending on the number of rows and columns in your input source.
Ignore Blank Rows
Allow Embedded Line Breaks
When selected, instructs the application to preserve embedded line breaks when importing columns.
Encoding
Specifies the encoding type to apply when loading the table into your workspace. The encoding types enabled for delimited-text files include:
- Code Page
- UTF-8
- UTF-16LE
- UTF-16BE
Code Page
When the Encoding type selected is Code page, this setting instructs the application to apply the selected code page to the table upon loading into your workspace.
Bulk Type Edit
NOTE: Specific data types can be assigned for each of the columns in your delimited text file data source using the Type drop-down lists provided to the right of each column.
This option is deactivated if Automatically sync columns with source data on load or refresh is selected.
CONVERSION OPTIONS
From text to numeric
Decimal Separator - Specifies the character to use as a decimal separator when converting text into a numeric value. You can select:
- Period
- Comma
From text to date
Date Format - Specifies the format of dates used when converting text into a date value. You can select:
- M/D/Y
- D/M/Y
- Y/M/D
First Year of Century - Specifies the first year of the century (100-year range) to use when converting two-digit years into four-digit years. The default value is 50 (i.e., 1950-2049).
Extraction Pattern - Specifies the pattern applied to a text string when converted into a date/time value. You can select:
- Date
- Date, then Time
- Time
- Time, then Date
Select OK to accept and save your changes. The dialog closes, and your settings are applied to the corresponding table.
Related Links
