Export Design
Export Design allows you to create or edit exports. You go to this mode within Export View.
The Export Design interface has the following elements:
Panel |
Description |
1 |
Ribbon Display all the tools you need to work with an export definition. Refer to the Export Design Ribbon Quick Reference. |
2 |
Export Selector Allows you to search for and/or select a specific export. |
3 |
Source Panel Allows you to view or edit the properties of your source. This panel displays a different set of properties depending on the source you have selected (report, table or summary). |
4 |
Output Panel Allows you to view or edit the properties of your output. This panel displays a different set of properties depending on the output type you have selected.. |
The Export Selector Context Menu
Right-clicking on the Export Selector displays a menu that will allow you to:
- Move a selected export up the selector
- Move a selected down the selector
- Duplicate an export
- Delete an export
