Exporting Data to Tableau Server
Monarch Data Prep Studio allows you to export to or update existing data sources in Tableau Server. To facilitate exports to this application, provide the necessary information (e.g., server URL, username, password, etc.) in the Server > Tableau Server sub-tab of the Application Default Settings dialog.
Note that, to enable successful exports to Tableau Server, you also need to have installed the Tableau TABCMD program. TABCMD is a command-line utility that allows users to automate administrative tasks on your Tableau Server site. Click here to download and learn more about the utility.
To begin your export, go to the Export Window, click the Add Export
button of the table you wish to export to Tableau Server, and then, from the options that display, select Tableau Server. -
Confirm the details of the indicated Tableau Server (the information here will depend on the server details you indicated in the Application Default Settings dialog) in the Export Properties panel.
Enter all of the required information:
Field
Export Location
The path and filename in which to export the .hyper file.
Data Source Name
The name of the data source. This will be the name that will be displayed on the server.
Site
The site in to which you are logging.
If the server has multiple sites and you are logging in to a site other than the default site, the target site must be identified.
This setting is optional.
Server Address
The server in which Tableau Server is installed.
If the server is in your local network, you can use http://localhost.
If the server uses SSL, you must specify https:// in the server name (e.g., https://<servername>).
If the server is using a port other than the default (i.e., 80), the port must be specified (e.g., http://altrtableauserver.com:1000).
Username
Your username for logging in to the server.
Password
Your password for logging in to the server.
If the Use password file option is selected, you must specify the path to your password file.
Proxy Address
The HTTP proxy server and port (host:port) in to which you are logging.
Path to TABCMD
The path to the TABCMD utility.
This path can only be edited via the Server > Tableau Server sub-tab of the Application Default Settings dialog.
Publish Type
The action to take if the table you are publishing already exists in the server:
Overwrite
Append
Replace
Filter
The filter to apply to the table, if applicable.
Sort
The sort to apply to the table, if applicable.
When file exists
The action to take if the file you are exporting to already exists in the export location specified:
Overwrite
Skip
If you wish to export your table to a different server site, you can modify the details specified in the server fields, including server address, username, password, and path to the TABCMD utility. To revert to the default values provided in the Application Default Settings dialog, click the Apply Defaults button. If you wish to edit your default values, click the Edit Defaults button instead. Note that the path to the TABCMD utility, by default, cannot be edited from the Export window. The path to this utility can only be edited in the Application Default Settings dialog.
Click the Export button when you are ready to export.
