Exporting a Report
Monarch Classic allows you to export data from the Report window. Unlike table and summaries, which allow exports to numerous file formats, you can only export a report to a TXT or PDF file. When exporting to a PDF file, the index definition will provide the bookmarks in the PDF file if you have configured the Report Index.
Go to Export View.
Select Create Export on the Export View ribbon. The Create Export dialog displays.
Enter the export File Name.
Select a report on the Source View selector.
Specify the Export File Type. Note that for reports, you can only select TXT or PDF as the output format type.
Check the Password box if you want the export output to be password protected.
Choose Run This Export to export the data or Close to save the export definition
