Function: Month
Returns the month (1-12) from a date.
Month(date)
Arguments
date can be a constant, a date field, an expression that results in a date or a function that returns a date.
Return value
This function returns a number in the range 1-12.
Calculated field example
If the Ship_date field contained the value 20010704, the following calculated field expression would return the value 7: Month(Ship_date)
Filter/Find example
Records with a date of 19910114, 19890131 or 19940107 in the Ship_date field can be selected or found using the expression: Month(Ship_date)=1
© 2024 Altair Engineering Inc. All Rights Reserved.
