Line of a Text Block by Line Number...
Extracts a line from a text block based on the number of the line in the block.
When you apply this operation to a text block, you must specify the number of the line in the block to extract.
Select Create new column to instruct the application to place the extracted line in a new column. Otherwise, the extracted line replaces the values in the original column.
Input/Output Data Type
Input |
Output |
text |
text |
In this example, Patient Information is the original column containing a text block. Extracting line #2 from the text block produces the values in Patient InformationLineByNumber.
