Application Settings
Select the Settings icon to modify application settings:
This displays a dialog box that will allow you to set the following:
Options
| Option | Description |
| General | Check on the box if you want all table names to be prefixed by the document name. |
| Conversion | These settings affect how information from text-based data sources is interpreted and converted to either the numeric or date/time format.
