Open Database Dialog
Monarch Classic provides an Open Database dialog that you can use to import data from an external database or delimited text file.
Once open, you can select the fields to import into Monarch Classic using the External Lookup window. Data that you import from an external database can be used just like data extracted from a report. You can apply filters to drill down the data, hide and rename fields, sort the data, create new calculated fields, create summary reports, print and copy data, and export data to any file format that Monarch Classic supports.
To access the Open Database dialog, do one of the following:
Select File tab, then Open, then Database. Note: This menu option is unavailable if a report file is open.
Select External Lookups from the Table Design ribbon, select Click to add a new External Lookup, and then Database from the drop-down.
Options
Field |
Description |
Data Source |
The Data Source combo box displays the name of the data source you select:
The combo box also includes a drop-down list that holds the most recently used data sources that you imported or joined data from. You may select a data source from this list, or use the Browse button to select a new data source. |
Browse Data Source |
When you click the Browse button, select one of the following from the drop-down list:
Source Type |
Displays the currently-selected Source Type. |
Table |
If you are defining the database for the first time, select a table using the Select Table button. Otherwise, this displays the currently-selected table. |
Select Table |
Click this button to display the Select Table dialog. You can then select from a list of available table in the data source. |
Model |
This is the name of the model you want to apply to a selected data source. If you previously imported data from the same data source and then saved a model file for that Monarch Classic session, the model file will include parameters that indicate which fields were imported along with the Monarch Classic field names that were assigned to those fields. |
Browse Model |
Use this button to select a model file to use. |
Include Password |
If you are importing from a password-protected data source, select this and enter the required password in the adjacent field. |
