Renaming a Table
You can rename a table to provide more meaningful or helpful descriptions for the tables you use in the Prepare Window.
Do one of the following:
Double click on the table's name on the Table List panel or
Click the drop-down arrow beside table you would like to rename and then select Rename Table from the context menu that displays.
The name is temporarily highlighted, ready to be modified:
Type the new name and hit Enter or click outside the text box.
Related Links
