| Button | Description |
        |  | Saves the specified settings and closes the Report Design window. |
        |  | Discards the specified settings and closes the Report Design window.  |
        |  | Displays the name of a selected template. |
        |  | Displays the role of a selected template. |
        |  | Adds a new template to the model. You can add one of the following template types:
            DetailAppendExclusionPage HeaderGroup FooterStart RegionEnd Region Note that only one detail, page header, start region, or end region template can be defined for any report; once these templates have been defined, they no longer appear as template options in the New Template dropdown. |
        |  | Deletes a selected template. |
        |  | Replaces the sample text used to guide your template-creation task. |
        |  | Redacts sensitive information from your sample text.  |
        |  | Specifies the template to use as a basis for stopping Monarch Classic from copying down information when applying an append or footer template.  |
        |  | Instructs the application to automatically define a trap for a selected template. |
        |  | Instructs the application to automatically define fields for a given template. |
        |  | Activates multi-column region mode, which is used to specify distinct columns in reports comprising multiple identical columns.  |
        |  | Activates Report Verify, which checks whether the fields defined for a template capture complete the required details. |
        |  | Launches the Report Colors dialog, which is used to define colors for specific templates.  |
        |  | Launches the Monarch Help file.  |
