Show Statistics
Displays statistics about a column. Statistics will show you, among others:
If your table has enough rows for you to work with
If there are nulls or blanks
The maximum, minimum, and average length of the values of the column
The number of unique values in the column
The sum of all values of a numeric column
Right-click on a column whose statistics you want to view.
Select Statistics > Show Statistics. The Statistics Panel displays.
To hide the Statistics Panel, select Hide Statistics
To refresh the statistics displayed after some operation, such as a filter, is applied to it, select the Refresh
icon.
In this example, statistics for the column Customer are displayed.
A quick review shows that:
No records have null values
There are 33 rows in the table
There are 15 unique customers in the table
