Using Aggregations
Monarch Classic includes aggregations which you can use to perform arithmetic functions on the values of a measure in a summary. The following types of aggregations are available in the Edit Measure Expression dialog:
Cumulative aggregations
| Aggregation | Description |
| Cum() | Returns the cumulative sum. |
| CumCount(*) | Returns the cumulative row count. |
| CumCountPct(*) | Returns the cumulative row count as a percentage of the total rows. |
| CumPct() | Returns the cumulative sum as a percentage of the total sum. |
Count aggregations
| Count(*) | Returns the count of rows (or non-null values of the field) within the group. |
| CountPct(*) | Returns the group row count as a percentage of the total rows. |
| CountSubPct(*) | Returns the group row count as a percentage of the row count in the next larger group. |
Percentage aggregations
| Pct() | Returns the group sum as a percentage of the total sum. |
| SubPct() | Returns the group sum as a percentage of the group sum of the next larger group. |
Statistical aggregations
| Avg() | Returns the average value of the field within the group. |
| Max() | Returns the maximum value of the field within the group. |
| Min() | Returns the minimum value of the field within the group. |
| Stdev() | Returns the standard deviation of the field values within the group. |
| StdevP() | Returns the standard deviation (with respect to the population) of the field values within the group. |
| Sum() | Returns the sum of the field values in the group. |
| Var() | Returns the variance of the field values within the group. |
| VarP() | Returns the variance (with respect to the population) of the field values within the group. |
Special aggregations
| Unique() | Returns the unique value of the field if there is a unique value, otherwise returns null. |
