Edit Password Dialog
When configuring an export to a PDF file, use this dialog to specify the password that must be supplied to open the file or restrict access to its contents.
Options
Field |
Description |
Password |
Enter the password you want to assign to the PDF file. |
Confirm password |
Confirm the password by entering it again. |
OK |
Click to save changes you have made to the settings and close the dialog. |
Cancel |
Close the dialog without saving changes. |
