Adding Dashboard Parameters
In addition to the parameters of the associated data tables that are used by visualizations and other parts on the dashboard, a Designer user can add new dashboard parameters which can be value sources inside actions and title of visualizations and parts.
- On the Dashboard and Workbook Settings pane, click the Dashboard tab.
- Click
A New Parameter instance is displayed.
- Click on this new instance.
- Enter the Name of the parameter then click
. - Select the data Type: Text, Numeric, or Time.
- Select the Mode: Text or Data
- For the Text mode, enter the Default Value then click
. You can enter several default values, separated by a comma.
NOTE: For the Time type, the following formats for the default value are accepted:
- "yyyy-MM-dd"
- "yyyy-MM-ddTHH:mm:ss"
- "yyyy-MM-ddTHH:mm:ss.SSS"
To prompt the parameter input when opening the workbook, tap the Prompted slider to turn it on. The dashboard parameter instance changes to allow specification of the following:
- To encrypt the value upon entry, tap the Masked slider to turn it on.
- Add a custom Input Validation. This can be any regular expression (e.g., “A-Z{3}”)
- The workbook will not be opened unless it passes the validation. Enter an Error Message to help in defining a better input to match the regular expression (e.g., “Enter another value.”)
- For the Data mode, the parameter is given a data-driven value either Once or Live.
Then select the Data Table, Column, and Aggregate.
For this sample data table:
Category id num X
a
1
X
b
1
X
c
1
Y
d
2
Y
e
2
Y
f
2
Z
g
3
Z
h
3
Z
i
3
If Once is the selected Data mode, the parameter is given a data-driven value once, at workbook startup and open, but it is not repeated when the data table is refreshed.
The first time you open the workbook and X is the category, the parameter data-driven num sum is 3.
Changing the category to Y, the parameter datadriven_num_sum is still 3.
However, if Live is the selected Data mode, the data-driven parameter is updated “live” and kept in sync with the data value.
The first time you open the workbook and X is the category, the parameter datadriven_num_sum is 3.
Changing the category to Y, the parameter datadriven_num_sum is updated to 6.
- Repeat steps 2 to 6 to add more parameters.
- Click the Save
button.
When saved, the
notification is displayed.
Deleting Dashboard Parameters
To delete a dashboard parameter, click on an instance in the list and then click
