Connector for Python
The Python connector lets you load data through Python. This can be useful for example when connecting to unusual data sources for which there is a client library in Python, or when you want to apply custom data transforms to the data in Python.
A requirement for using the Python connector is that your Panopticon server has been configured to integrate with a running Python environment, as described in the Real Time Installation and Reference Guide.
The Python connector has settings that may be pre-configured by the Panopticon server administrator, and thereby not exposed to the users of the connector. If the settings are not pre-configured, you will see the following settings:
When using Pyro4 integration:
Setting Description
Host
The hostname or IP-number where Python is running.
Port
The port number where Pyro4 is listening.
HMAC Key
A secret password set in the integration configuration that must be matched.
Serialization Type
Can be either serpent or pickle.
When using FAST API integration (Linux servers only):
Setting Description
Host
Port
The port number where FAST API is listening.
You will also see the following settings:
Setting Description
Show in Timezone
Optional. The Timezone to use when showing datetime values returned from Python.
Source Timezone
Optional. The Timezone that should be assumed for datetime values handed to Python as part of your code.
Python Script (checkbox)
Whether Apache Arrow serialization should be applied to the data during transfer from Python to Panopticon. This will make the data transfer significantly faster.
NOTE:  If your Panopticon server has not been configured for integration with a Python environment, you will not be able to use the Python connector, regardless of what settings you make in the connector.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
