Managed Altair Units License SSL Error
If you encounter the following issue when using Managed Altair Units license:
"SSL_ERROR_SSL
error:14007086:SSL routines:CONNECT_CR_CERT:certificate verify failed
unable to get local issuer certificate"
Detail: SSL/TLS handshake failed
Follow the steps below to resolve this error:
- Make sure you have installed all updates and are using the latest version of the product. The latest version is always available from the Marketplace.
- Work with your IT department to create an exception in your proxy for the traffic going to our servers:
