Creating DolphinDB - Streaming Input Data Source
The DolphinDB streaming connector allows you to connect and subscribe streaming data using DolphinDB Java Streaming API.
- In the New Data Source page, select Input > DolphinDB – Streaming Beta in the Connector drop-down list.
- Enter the following information:
Property Description Host
DolphinDB - Streaming host address.
Port
DolphinDB - Streaming host port. Default is 8848.
User Id
The user Id that will be used to connect to the DolphinDB - Streaming service.
Password
The password to connect to the DolphinDB - Streaming service.
Select the Show Characters checkbox to display the entered password characters.
Table
Table to subscribe against.
- Select the From Beginning checkbox to subscribe from the beginning to the latest messages.
If not selected, you will only be subscribed to the latest messages.
- Click
to retrieve the schema of the configured subscription.
This populates the Id Column with the set of columns from the schema of type sym and the text array such as Character/Boolean/GUID, etc. The selected Id Column can be used to select a key column to manage data updates and inserts.
NOTE: Every message definition needs a text column to be defined as the Id column. By default, only the latest data will be loaded into memory.
Furthermore, a streaming time series window can be generated by creating a compound key with the Id Column, plus a separately specified Time ID column. This Time ID column can be from the source dataset, or alternatively automatically generated.
If the Time Id column is selected, then a scrolling time window can be specified.
For Automatic Time Id, define the Time Id Column Name.
As new data arrives from the subscription, new time slices will automatically be added, and old ones will be deleted.
If a new Id is received, a new row is added to the in-memory data set representing the DolphinDB - Streaming topic subscription. While if an existing ID is received, an existing row is updated.
- Define the Real-time Settings.
- Click
. The new data source is added in the Data Sources list.
