Creating MQTT Input Data Source
The MQTT connector allows:
- Connection to MQTT’s message bus on a real-time streaming basis.
- Panopticon Streams to subscribe to FIX, JSON, Text or XML based messages that are published on particular topics. The data format itself is arbitrary, and consequently, the connection includes the message definition.
- Encrypted/SSL connections using a generated CA certificate file.
- In the New Data Source page, select Input > MQTT in the Connector drop-down list.
- Enter the following information:
Property Description Broker URL
The location of the message broker. Default is tcp://localhost:1883.
Topic
The topic or the queue physical name.
Example:
level1/level2/level3/level4 etc.
NOTES:
You can also opt to use a wild card in the topic name specification.
- The plus sign symbol (+) can be used as a wild card for any value at one specific level.
Example: level1/level2/+/level4
- The hash sign symbol (#) can be used as a wild card for any values across more than one level.
Example: level1/#/level4
User Id
The user Id that will be used to connect to MQTT.
Password
The password that will be used to connect to MQTT.
- To allow encrypted connections, you can either:
- Upload a CA Certificate file by clicking Upload File
then Browse
to browse to the file source.
After selecting the file, it is displayed with the timestamp.
To change the certificate, click
then Browse
to browse to a new version of the file. - Link to a CA Certificate file by clicking Link to File
and entering a File Path.
- In MQTT, a topic consists of one or more topic levels. Enter the Topic Level Separator to use. Default is / (forward slash).
- Select the Message Type.
- Select either the period (.) or comma (,) as the Decimal Separator.
NOTE: Prepend 'default:' for the elements falling under default namespace.
- Click
to the fetch the schema based on the connection details. This populates the list
of columns with the data type found from inspecting the first ‘n’ rows of the input data source. - You can also opt to load or save a copy of the column definition.
- You can also opt to click
to add columns to the MQTT connection that represent sections of the message. Then enter or select:
Property Description Name
XPath/JsonPath/Fix Tag/Column Index
The XPath/JsonPath/Fix Tag/Column Index of the source schema.
The data type of the column. Can be a Text, Numeric, or Time.
Date Format
NOTE:
To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
For example: yyyy-MM-dd HH:mm:ss.SSSSSS
Filter
Defined parameters that can be used as filter. Only available for JSON, Text, and XML message types.
Enabled
Determines whether the message field should be processed.
To delete a column, check its
or all the column entries, check the topmost
, then click
. - Text for topic levels can be consumed as additional columns into the data table.
The Topic Columns section shows and allows defining data table columns and mapping them to topic hierarchy levels (index based from left, 0 based).
Like columns from message data, manually add them by clicking
. A new entry displays.
Name can be any unique topic level within the topic name. The Level is the hierarchy level of the topic column.
Select the Enabled checkbox to enable a topic column.
To delete a topic column, check its
or all the topic column entries, check the topmost
, then click
. - Define the Real-time Settings.
- Click
. The new data source is added in the Data Sources list.
