Damper
Linear 1D translational damper
    Damper
Modelica/Mechanics/Translational/Components
Linear, velocity dependent damper element. It can be either connectedbetween a sliding mass and the housing (model Fixed), orbetween two sliding masses.
Damper_0
mo_s_rel
s_rel
s_rel
Structure
mo_s_rel/fixed
fixed
Cell of scalars
true
false
mo_s_rel/start
start
Cell of scalars
mo_v_rel
v_rel
v_rel
Structure
mo_v_rel/fixed
fixed
Cell of scalars
true
false
mo_v_rel/start
start
Cell of scalars
mo_d
d
Damping constant
Scalar
mo_useHeatPort
useHeatPort
=true, if heatPort is enabled
Number
0
1
Damper_1
mo_stateSelect
stateSelect
Priority to use s_rel and v_rel as states
Structure
mo_stateSelect/choice1
StateSelect.never
Number
0
1
mo_stateSelect/choice2
StateSelect.avoid
Number
0
1
mo_stateSelect/choice3
StateSelect.default
Number
0
1
mo_stateSelect/choice4
StateSelect.prefer
Number
0
1
mo_stateSelect/choice5
StateSelect.always
Number
0
1
mo_s_nominal
s_nominal
Nominal value of s_rel (used for scaling)
Scalar
Damper_2
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'f'
'lossPower'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
flange_a
implicit
Left flange of compliant 1-dim. translational component
input
1
flange_b
implicit
Right flange of compliant 1-dim. translational component
output
1
Port 3
implicit
Optional port to which dissipated losses are transported in form of heat
input
mo_useHeatPort
See Also
