Analysis
The Analysis panel allows you to add new analyses to your model, modify attachments, set initial conditions for analyses, and set analyses options.
Analyses can be selected from the Project Browser. The Project Browser context menu is used to turn the currently-selected analysis on or off.
To activate an analysis: right-click on the analysis in the Project Browser and select Activate (all other analyses which are active will be deactivated).
To deactivate an analysis: right-click on the active analysis in the Project Browser and select Deactivate. When an analysis is turned off, it is dimmed in the browser, and is turned off in the graphical display.
Note: Entities within any Analyses that are turned off are not written to the
solver.
The Analysis panel contains the following tabs:
- Attachments
- Options
- Initial Conditions
- System Translation
- Import/Export
