Create Linear Gap Elements
Create linear gaps between corresponding pairs of nodes from one plate to another plate along the axis of a local coordinate system.
- From the menu bar, click .
- Select the Dependent Nodes from the first plate.
- Select the Independent Nodes from the second plate.
- Assign the correct Tolerance, which is slightly bigger than the gap.
- Select the degree of freedom (DOF) for the MPC (1, 2, 3, 4, 5, or 6).
Click Apply.
A Nastran linear gap is created that consists of MPC, SPC, SPOINTS and SUPPORT. For example, the following cards are created.
SPOINT 55 155 (two spoints 55, 155)
SUPPORT 55 0 (support at one spoint)
SPC 101106 155 0 .05 (spc at the other spoint with initial gap of 0.05, with DOF=0)
$ SID G1 C1 A1 G2 C2 A2 (MPC for linear gap. In DOF = 2 for Nastran)
MPC 101106 3 2 1.0 2 2 -1.0
$ G3 C3 A3 G4 C4 A4
55 0 1.0 155 0 -1.0
Note: You can also use this tool to convert other types of 1D connector elements, such as CGAP, CBUSH, CELAS, to linear gap (MPC/SUPORT, SPC, SPOINT).Figure 2.
