Calculate Summary Measurements
Use the Query tool to measure areas, volumes, entity counts, line lengths, bounding boxes, and more.
Click the arrow next to the Home tool set, then
select Query.
Select entities to measure in the modeling window.
The supported entity types are: parts, solids, surfaces, lines, points, and nodes.
Based on the entity type, the available measurement information may change.
- Optional:
Click
in the microdialog to
toggle bounding box visualization.
Click Compute to generate measurements for you
selection.
Tip: You can copy printed information from the text box and use it for any other dialog.
