Detach Solids
Use the Boolean: Detach tool to separate selected solids from neighboring solids that share one or more common faces.
Shared or partition faces between selected solids and surrounding solids duplicate to become bounding faces of the separated solids. Partitioning faces within the selection are maintained after they are detached from the rest of the model.
From the 3D ribbon, click the tool.
- Select solids.
In the microdialog, select one of the following
options:
Option Description
Detach all
Selected solids detach from neighboring solids and each other.Figure 2.
Detach from each other
Selected solids detach from each other but maintain an interface with neighboring solids.Figure 3.
Detach from not selected
Selected solids detach from neighboring solids while maintaining an interface within themselves.Figure 4.
- After you have made your selection, click Detach.
