Manufacturing Solutions
Blank Nesting
Blank Nesting
Blank Nesting
The Blank Nesting tool lets you create numerous configurations to determine optimal material usage for stamped sheet metal components.
To start it, ensure you are in the Radioss One Step interface. Then go to the Blank Layout ribbon, and select blank_nesting_icon. A new Blank Nesting dialog opens and includes the following options.
File Menu
From the toolbar, click File and select from the following options:
Option
new_hm_file_icon New Session
Clears an existing nesting and refreshes the current session by deleting the entries in the Log window.
Open Session File
Loads a saved session file saved with a default *.nsw ASCII file extension.
save_file_iconSave Session File
Saves a current session including setup, log and model information with a *.nsw file extension. The session file is stored in a fixed field ASCII format.
Save Session File As
Lets you save a session with a new name.
import_file_iconImport
Imports the utility-specific model files {fixed field ASCII format} with file extensions *.txt or *.nxy.
export_file_iconExport
This option exports the blank nesting shape in the current session as an.iges file.
Recent Files
This option displays the recently imported session files and lets you launch or import the files into the current session.
Recent Imports
This option displays imported *.nxy files (blank models) into the session and helps to quickly launch or import the files into the current session.
Exit
Closes the utility and returns to the parent HyperForm session.
Edit Menu
From the toolbar, click Edit and select from the following options:
Option Name
Duplicate
Lets you copy a selected blank for use in a nesting layout using Auto nesting or other nesting options.
Delete
Removes a selected blank from the nesting layout.
Flip-X / Flip-Y
Flip-X rotates a selected blank by 90 degrees along the X axis. Flip-Y rotates a selected blank by 90 degrees along the Y axis.
Snap to best-in-move
Lets you move or rotate a selected blank along the XY plane to ensure maximum utilization of the coil type or sheet type nesting setup. The nesting setup automatically updates and adjusts in reference to the blank positioning.
Autosnap to best-in-move
Lets you move or rotate a selected blank along the XY plane, similar to the snap to best-in-move feature, but the blank automatically snaps to the best location.
Lock Rotation
Locks the blank's rotation while you position the blank.
View Menu
From the toolbar, select View. The View menu displays the following options:
Option
fit_iconFit
Spans the model within the window area for better viewing.
zoom_iconZoom +/-
Scales the model view up or down. From the tool bar, left-click to scale down and right-click to scale up.
Auto Center
Click Auto Center, then right-click on the blank to center the component and position it along the XY plane.
Best Dimensions
Displays your best fit dimensions from various attempts that are stored in memory.
User Dimensions
Graphically displays input Height and Pitch dimensions.
Angles
Displays the angle of rotation of the blank in an XY plane on the screen and refreshes as you rotate the model.
Setup
Toggles the display of the Setup Browser on the Blank Nesting window.
Tools Menu
Option
Report
This option exports an *.html file with all nesting details including the nested pattern and image as seen in the log window.
Log Options
This option lets you set the number of rows to display in the log window.
Help Menu
Option
About
This option displays a window with the version details of the nesting utility.
Log Window
The Log Window displays nesting details and layout information as you see in the following figure:
blank_nest_log_window
The blank nesting module automatically stores a set number of moves.
1.To specify moves, select Tools > Log Options…
2.To manually store a move, on the toolbar, select Store Current. Once the number of moves exceeds the log capacity, each new move is compared against the move with the least efficiency, and the more efficient move is saved.
At any point, you can select the information in the Log Window to view and restore a nesting setup.
Utilization Statistics
Utilization statistics appear at the top of the graphics display, as shown in the following image:
hypernest2
The calculations displayed include:
•Current: The current material utilization, which is calculated as the area of the blanks divided by the total area within the pitch, multiplied by 100. The value is expressed as a percentage. An overlap or penetration is also indicated by the color of the blank changing to red.
•Best in Move: A move is any series of modifications with respect to the blank that is currently being moved. The Best in Move value is the highest material utilization value in the current move. The Best in Move value resets to 0 when the move action is shifted to a different blank.
•Best in Session: This is a best utilization value achieved among all moves in the session.
Setup Options
Option
Nesting Setup
The setup offers two types of layouts:
•Coil type: Coil nestings are based on an infinitely long sheet of metal with a nesting pattern separated by a pitch.
•Sheet type: Sheet is a default selection. Sheet nestings use a single portion of sheet metal.
Dimension
The Height and Pitch include these options:
•Optimum: This value is estimated from nesting and is automatically populated.
•Custom: You can enter a custom value.
Margin
•Part to part: Distance between two parts.
•Part to edge: Distance between the part and the sheet/coil edge.
Carrier
Select Carrier, and then select a type from the pull down menu. In addition, specify two dimensions:
•Carrier Height: Height/width of the carrier.
•Part to Carrier: Distance between the part and the carrier.
Part
Orientation
•Optimum (default): Automatically determined from nesting.
•Current: Takes the current orientation for nesting without altering or rotating it.
Addendum
This is the extra material that needs to be added all around the part's outer edge. The revised blank size is used for nesting.
Cost Estimation
•Density: Density of the material
•Thickness: Thickness of the material.
•Cost: Cost per Kg of the material.
Move Part
To move a part to a specified location, enter values in the dx, dy and dα fields, and then click Apply, or click Reject to move the part back to the previous position.
Measure Options
blank_nest_measure_tab
The Measure tab in the Blank Nesting utility measures the distance between various points on the component/blank.
Select a point anywhere on the blank to display a distance. Distance is also updated in the respective text boxes on the browser.
Note: While measuring, you can select one point at a time to display the distance between the current location with respect to the previous location points.
Context Sensitive Menus
blank_nest_context_menu
Right-click anywhere in the utility session and a context menu with commonly-used options appears.  The options are described in the following table.
Option
fit_iconFit
Spans and fits the model within the window area for better viewing.
zoom_iconZoom +/-
Scales the model larger or smaller.
store_current_iconStore Current
Stores the nesting information of a selected blank. Use this feature to store information intermittently during positioning. Saved nesting information is appended in the Log window and can be retrieved and restored at a later time.
Best Dimensions
Displays the best fit dimensions from the various attempts that are stored in memory.
User Dimensions
Displays the user input Height and Pitch dimensions graphically.
Lets you move or rotate a selected blank on the XY plane. This feature is similar to snap to best-in-move, but the blank snaps to the best position automatically while moving.
Lock rotation
Setup
blank_nest_context_menu_2
Right-click a displayed model and an extended version of the above context menu appears.  The additional options are described in the following table:
Option
Duplicate
Delete
Flip-X / Flip-Y
Lets you move or rotate a selected blank along the XY plane to ensure maximum utilization of the coil type or sheet type nesting setup. While doing so the nesting setup automatically updates and adjusts per the blank positioning.
Save current blank as
Exports a selected model as a .nxy file. You can use the import option to bring back the file into the session at any time.
Standard Nesting Patterns
A toolbar is also available for rapid creation of standard nesting patterns. The following icons are available:
Icon
dupliate_and _position_along_xaxis
One-Up: Creates a blank nesting of a single blank.
Duplicate_position_with_respect_to_yaxis
Two-Up: Creates a blank nesting of two blanks with the second blank being a copy of first blank.
duplicated_reflect_position_xyaxis
Two-Up-Flip: Creates a blank nesting of two blanks with the second blank being a copy of first blank and flipped.
duplicated_reflect_position_yaxis
Two-Up-Mirror X: Creates a blank nesting of two blanks with the second blank mirroring the first blank about the X axis.
Duplicate_reflect_position_with_respect_to_xaxis
Two-Up-Mirror Y: Creates a blank nesting of two blanks with the second blank mirroring the first blank about the Y axis.
position_adjacent
Positions the blanks adjacent to each other without any rotation such that it maximizes percentage utilization in sheet/coil.
rotate_together
Rotates selected blanks together such that it maximizes percentage utilization in sheet/coil.
icon_auto_nesting
Nests selected arbitrary blank shapes.
In addition to the icons listed above, you can click the small icon on the bottom right corner of the Setup/Measure tab area to hide tabs and enlarge the graphics area. To display the tabs again, from the View menu, select Setup.
See also
Tools
