Manufacturing Solutions
Drawbeads Editor
Drawbeads Editor
Drawbeads Editor
The Drawbeads Editor can be started by clicking the Setup menu, or from clicking a drawbead entry in the Auto Process macro. The Drawbeads Editor helps you quickly design drawbeads from lines for an analysis. You can also work with drawbeads created from components, nodes, or geometry files.
Follow these steps in the Drawbeads Editor to create and modify drawbeads for your analysis:
1.Use the drawbeads_createline_btn button to draw a line on the top-down, simplified graphical representation of the model in the center area of the Drawbeads Editor. The line drawing tool works by clicking nodes that define the endpoints of the line (or points on a curve). As you select additional nodes, a blue line connects them. See the chart below for details of the tools available in the Drawbeads Editor.
drawbeads_line
Once you have completed the nodes, click the Create button. The line becomes yellow and an entry for a drawbead appears in the table below.
drawbeads_created.zoom75
2.Complete the data fields for the drawbead in the table. Specify the following items:
Option
Source
Select which type of source data you are using to define the drawbead: line, component, nodes, or geom file:
•line: Drawbead data will come from existing lines in the model.
•component: If existing drawbead data is located in a specific component, select this option and select the component that serves as the source from the adjacent field.
•nodes: The drawbead data will come from nodes drawn in the Drawbeads Editor.
•geom file: Source data is from a geometry file in IGES format. Browse to the IGES file in the adjacent field.
Blank
The component on which the drawbead acts.
Tool
The component where the drawbead is attached.
Height
The height of the drawbead.
% lock
The percentage of the required necking force to apply as the force for the drawbead.
RF
The restraint force. Click the … button to use the Drawbead Calculator to calculate new force values based on different model parameters.
NF
The normal force. Click the … button to use the Drawbead Calculator to calculate new force values based on different model parameters.
3.Click Update to perform the drawbead calculations, draw the load curves, and project the nodes that correspond to the drawbead orientation on to the surfaces of the die.
Drawbeads Editor Toolbar
The following tools are available on the Drawbeads Editor toolbar.
Button
Function
db_disp_sel
In the drop-down menu, select Both to display both the drawbeads and lines in the model representation, Drawbeads to display only the drawbeads in the model representation, or Lines to display only the lines in the model representation.
db_createdb_btn
Create a drawbead by clicking points to define the line. When the points are in place, click Create to set the line and create a corresponding drawbead based on the line.
db_adddb_btn
Click to add a drawbead to the table. Then complete the fields for the row in the table to define the drawbead.
db_selectline_btn
Click lines to select them. Lines appear as blue dashes. When they are selected, they become yellow.
db_adddbline_btn
Click to add a drawbead for each line.
db_deldb_btn
Click to delete the active drawbead from the table. The active drawbead in the table has a gray arrow next to it.
db_delalldb_btn
Click to delete all drawbeads.
db_select_btn
Click on a drawbead in the model to select it.
db_movedb_btn
Click a drawbead to select it and then click and drag endpoints to change the size of the drawbead.
db_splitdb_btn
Click a point on a drawbead to split the drawbead into two drawbeads at that location.
db_combinedb_btn
Click two when the button is selected to combine them into a single drawbead.
db_undo_btn
Click the button to undo the last action in the Drawbeads Editor.
db_mode_sel
In the drop-down menu, select:
Force to set the force calculation mode as the default, which requires that you supply values for restraining and closure forces. You can also use the Drawbead Calculator to determine values.
or
%-lock to set the force calculation mode as percent lock, which applies force as a percentage of the required necking force.
db_fit_btn
Click to fit the model to the current window size.
db_zoom_btn
Zoom feature. Click once to fit the model in the window. Click and drag to draw a rectangle to zoom in on that selection area.
db_pan_btn
Click and drag to move the viewing area when the model is zoomed in.
