Manufacturing Solutions
Features and Capabilities
Modeling Capabilities
Metal Extrusion
•Direct/indirect extrusion
•Hot/cold extrusion
•Single or multi-cycle extrusion
•Profile deformation
•Modeling bearing with choke angle
•Optimization of bearing design
•Transverse weld length prediction
•Tracking billet skin impurities
•Tool deflection and tool stresses
•Advanced heat transfer features such as billet taper, tool heat transfer, etc.
•Grain size prediction
•Yield stress prediction
•User-defined (C or FORTRAN) functions
Metal Rolling
•Hot rolling
•Cold rolling
Friction Stir Welding
•Material flow and heat transfer analysis
Polymer Processing
•Profile extrusion
•Film/sheet extrusion
•Co-extrusion
•Runner balancing
•Polymer melt flow
•Steady/unsteady flows with heat transfer
Material Constitutive Models
Metals
•Sine hyperbolic inverse model
•Metal Forming Power Law
•Temperature Dependent Norton-Hoff model
•Hensel Spittel Material model
-Glass Properties
Polymers
•Power-law
•Spriggs-truncated Power-law
•Carreau Model
•Cross Model
•Modified Cross Model
•Herschel-Bulkley Model
•Criminale-Ericksen-Filbey Viscoelastic Model
•Casson Thixotropy Model
Temperature Dependence Properties
•Table or Expression
•Exp(Q/RT) (Metal and Polymer)
•Exp(-beta(T-To)) (Metal and Polymer)
•Exp(Tb/T) (Polymer)
•WLF (Polymer)
Platforms/Operating Systems
•32-bit architecture
-Windows
•64-bit architecture
-Linux
-Windows
See Also:
Recommended Computer Hardware Specifications
