Manufacturing Solutions
HyperForm One-Step Input Cards
Below is a summary of the content of an input deck for a One-Step analysis. Each card is defined in its rigid format form and is shown as a number of fields with a length of 10.
In the following listings:
•The Type is the variable type and is either F, for floating point, I for an integer, or C for a character. The default gives the value set if the field is left blank or the card is not defined.
•Any variables used for property ID as keywords should be positive and defined in the corresponding property card, which will share the same color.
•Any card in italic is optional.
The @HyperForm line is the first line of the file, in the parameter section.
The following cards appear in the bulk data section, between "Begin Bulk" and "ENDDATA".
Friction on the Curvature
PARAM
Variable
Default
COEFF
C
N/A
Coefficient of friction on the curvature.
MU
F
0.1
The value of the coefficient of friction on the curvature. It should not be negative.
Nodes (Grid Points)
GRID
Variable
Default
G
I
none
Grid point identification number
CP
I
0
Coordinate system ID in which grid point is defined
X1, X2, X3
F
none
Location of the grid point in the coordinate system
CD
I
0
Coordinate system Id in which the displacements, DOFs, constraints and defined at the grid point
PS
F
none
Permanent single point constraints associated with the grid point
Elements
CTRIA3
Variable
Default
EID
I
none
Element ID
PID
I
none
Property ID of PHFSHL entry
G1
I
none
Grid point ID
G2
I
none
Grid point ID
G3
I
none
Grid point ID
CQUAD4
Variable
Default
EID
I
none
Element ID
PID
I
none
G1
I
none
Grid point ID
G2
I
none
Grid point ID
G3
I
none
Grid point ID
G4
I
none
Grid point ID
Element Properties
PHFSHL
Variable
Default
PID
I
none
Property ID of a PHFSHL entry
MID
I
none
Material ID
T
F
none
Thickness of PHFSHL
BHID
F
none
Blankholder ID
BDRID
I
none
Flag for curved binder
FLDID
F
none
Forming limit curve ID
Material Properties
MATHF
Variable
Default
MID
I
none
Material ID
E
F
none
Young’s Modulus
NU
F
none
Poisson’s Ratio
Y
F
none
Yield stress
K
F
none
Strength coefficient
n
F
none
Strain-hardening component
EPS0
F
none
Pre-strain coefficient
FLD0
F
none
The lowest point on the failure curve
R0, R45, R90
F
none
Lankford coefficients
User-defined FLD
FLDATA
Variable
Default
FLDID
I
none
E1
F
none
Minor strain value
E2
F
none
Major strain value
Blank Holder Forces
BLKHDF
Variable
Default
BHID
I
none
Blankholder ID
MU
F
none
Coefficient of friction. It should be positive.
FORCE
F
none
Blankholder force
Toggle
F
none
Flag assigned based on option (pressure/tonnage force)
Edge Blankholder
EDGEBH
Variable
Default
EID
I
none
Element ID
S1, T1
F
none
Parametric coordinates of the entry points for the line
|S1,T1|<=1.0
S2, T2
F
none
Parametric coordinates of the exit points for the line
|S2,T2|<=1.0
FORCE
F
none
Blankholder restraining force
SID
I
none
Blankholder set Id for retrieving the deck back to HyperForm. It is not used in the solver.
Drawbeads
EDRAWB
Variable
Default
EID
I
none
Element ID
S1, T1
F
none
|S1,T1|<=1.0
S2, T2
F
none
|S2,T2|<=1.0
FORCE
F
none
Drawbead restraining force, N/mm
SID
I
none
Drawbead set ID for retrieving the deck back to HyperForm. It is not used in the solver.
Lock Beads
MPC
Variable
Default
SID
I
none
Set ID
G
I
none
Grid ID
A1, A2
F
none
Slope coefficient
Boundary Conditions
SPC
Variable
Default
SID
I
none
Set ID
G1, G2
I
none
Grid ID
C1, C2
F
none
Constraint type
1: constraint in X-axis
2: constraint in Y-axis
12: constraint in XY-axis
D1, D2
F
none
Displacement
