Manufacturing Solutions
Key New Features
Key New Features
Key New Features
Major enhancements in the latest HX solver include:
•Metal Extrusion
oUser Defined Functions in FORTRAN/C for:
▪Material model
▪Grain size
▪Yield strength
▪Up to five nodal results
▪Up to five elemental results
oViscoplastic Friction Model
oImprovements to bearing profile friction computations to improve the accuracy of stick/slip behavior
oNew Results
▪Grain size
▪Yield strength
▪Weld strength
•Nose Cone Prediction in steady state analysis
•Polymer Extrusion
oCriminale-Ericksen-Filbey viscoelastic model
Major enhancements in the user interface include:
•Metal Extrusion
oSupport for layered CAD in the Extrusion Wizard
oAutomatic mesh size estimation in the Extrusion Wizard
oImprove Mesh utility in Extrusion Wizard
oPress database
oCreate bearing lines from bearing curve
oMaterial constitutive data for SineHypInv material model from flow stress tables (as function of strain rate and temperature)
oHensel Spittel material model added under constitutive model
oProject Browser for Extrusion Wizard
oTube Extrusion Wizard
oTool Deflection Analysis
oUser Interface for editing Bearing optimization data
oUser Interface for editing Billet data
oUser Interface for creating Billet
oUser Interface for Quick Solid Edit
oRedesigned Create/Edit BCs panel
oBearing profile gap thickness computation
•Polymer Processing
oPlate Meshing Wizard
oCoextrusion Wizard
oTire Extrusion Wizard
oRunner Balancing Wizard
oMaterial constitutive model from viscosity tables (as function of strain rate and temperature)
oMelt Flow Analysis Wizard
oProject Browser for Plate Meshing Wizard, Coextrusion Wizard, Runner Balancing Wizard and Melt Flow Analysis Wizard
oCapability to start from an existing mesh in Plate Meshing Wizard, Coextrusion Wizard, and Melt Flow Analysis Wizard.
oImprove Mesh utility for Plate Meshing, Co-extrusion and MeltFlow Wizards
See Also:
HyperXtrude User Profile
