Manufacturing Solutions
Material Data - Preform
There are three materials involved in the filling process, they are the Preform, resin and air. Preform is modeled as a porous media. The MATERIALS data packet specifies the Preform data.
BEGIN MATERIALS
PorousMediaProps Material_name {
Permeability_X = K_x
Permeability_Y = K_y
Permeability_Z = K_z
Porosity  = Value
Residual_Resin_Satn = Value
Residual_Air_Satn = Value
Initial_Resin_Satn = Value
Relperm_curve = ( 1 | 2 | 3 )
Compressibility = Value
Density = Value
Conductivity_X = k_x
Conductivity_Y = k_y
Conductivity_Z = k_z
SpecificHeat = Value
END
•Permeability tensor is orthotropic and its units are m2. Data can be specified using a table or function. Depending on the mat type, values are in the range, 10-8 to 10-12.
•Porosity is the complement of fiber volume fraction, indicating pore volume space. This is a dimensionless variable.
•Saturation is always expressed in terms of the resin’s saturation. Residual saturation of resin should be 0.0, that is, there is no resin residue in material by default. Residual saturation of air should be 1.0, as this implies all the air in the preform can be removed.
•There are three different functions available for the relative permeability curve. These curves specify how the presence of resin influences the permeability of air and the vice versa.
-Linear
-Quadratic
-Experimental
•Density, thermal conductivity and the specific heat are required only for non-isothermal analysis. Preform is treated as an orthotropic material with respect to heat conduction.
•All units are in S.I. unless specified to the contrary.
BEGIN MATERIALS
PorousMediaProps random_mat {
Permeability_X = 1.0E-09
Permeability_Y = 1.0E-09
Permeability_Z = 1.0E-09
Porosity  = 0.70
Residual_Resin_Satn = 0
Residual_Air_Satn = 1
Initial_Resin_Satn = 0
RelPerm_Curve = 2
Density = 2700.0
Conductivity_X = 0.04
Conductivity_Y = 0.04
Conductivity_Z = 0.04
SpecificHeat = 2000
END
Variable
Default Value
Valid Range
Data Type
Significance
Permeability_X
1.0e-08
1.0e-04 -
1.0e-15
Constant or Function of time
Permeability in the X direction
Permeability_Y
1.0e-08
1.0e-04 -
1.0e-15
Permeability in the Y direction
Permeability_Z
1.0e-08
1.0e-04 -
1.0e-15
Permeability in the Z direction
Porosity
0.60
0.1 - 0.9
Constant or function of time
Porosity = 1 - fiber volume fraction
Residual_Resin_Satn
0.0
0.0 - 1.0
Constant or function of x and y
Default value should be fine for RTM/ZPM
Residual_Air_Satn
1.0
0.0 - 1.0
Initial_Resin_Satn
0.0
0.0 - 1.0
Relperm_Curve
2
1 - 5
Constant
1 - Quadratic
2 - Linear
3 - VARTM
4 - Digital
5 - User
If you specify 5, then you should also specify the PROBLEMDATA type RelPerm
PoreSize
1.0e - 04
-1 or average poresize
Constant
Use -1 to compute shear rate based on Darcy's velocity field. A valid non-zero value would lead to shear rate calculation based on pore size.
Density
1000.0
Positive value
Density of the preform
Conductivity_X
0.04
Positive value
Thermal conductivity of the preform in X direction
Conductivity_Y
0.04
Positive value
Thermal conductivity of the preform in Y direction
Conductivity_Z
0.04
Positive value
Thermal conductivity of the preform in Z direction
SpecificHeat
2000.0
Positive Value
Specific heat of the preform
