HyperForm generates results files, .res, containing the following output, which can be viewed from the Contour panel:
where:
= initial thickness
t = final thickness
Note: Element percentage thinning values are positive when the material thins out.
- | This is the same as strain mode and is the angle between the line joining the minor strain (x-axis), major strain (y-axis) plot of an element to the origin and the major strain axis (y-axis), clockwise being positive. This gives a measure of the relative tension and compression at each element on the blank surface. |
- | Same as shown under the FLD plots panel. For elemental values, click assign. |
See Also:
User's Guide
