Manufacturing Solutions
RADIOSS Incremental
RADIOSS Incremental
Previous topic Next topic Expand/collapse all hidden text
RADIOSS Incremental
The following HyperForm Settings options are available for the RADIOSS Incremental user profile:
expand-green-10Settings Tab
RADIOSS Incremental
Settings Option
DefaultProcess
Name of the process to display if the process contains no data.
AutoPosTol
(Auto Positioning Tolerence)
Lets you specify two values: 0 to Disable or 1 to Enable. Enable moves the tools during auto positioning to get roundoff numbers. This option is valid only for Auto Process.
AutoCompNames
Lets you specify two values: 0 to Disable or 1 to Enable. Components are set based on the pattern below for each tool object:
•Die Pattern: Default string: die*
•Punch Pattern: Default string: punch*
•Blank Pattern: Default string: blank*
•Binder Pattern: Default string: binder*
•Support Pattern: Default string: support* or pad*
•UpperBinder Pattern: Default string: upper*
•LowerBinder Pattern: Default string: lower*
•WiperPattern: Default string: wiper*
CurveIntegration
Lets you specify two values: 0 to Disable or 1 to Enable. The Disable curve area is located in the details page of the AutoProcess. Default: 1.
CloseConfirmation,Setup
Asks for confirmation when you click Close in the setup page. Three options are available: 0: Never ask; 1: Ask if you have changed a value but have not clicked Apply; and 2: Always ask. Default: 0.
CloseConfirmation,Drawbeads
Asks for confirmation when you click Close in the setup Drawbead editor dialog. Three options are available: 0: Never ask; 1: Ask if you have changed a value but have not clicked Apply; and 2: Always ask. Default: 0.
CloseConfirmation,Details
Details
Displays the details page in Auto Process. Three options are available: 0: Hide; 1: Partial display; and 2: Full display. Default: 1.
UserMaterialPath
Points to the directory where the materials you created are stored.
MaterialDatabase
Points to the location of the material database that is included with the HyperForm installation.
RADIOSS_ARGUMENTS
Arguments to be passed on for the solver run. Defaults:
•–both : Run both starter and Engine
•–noh3d : Don’t generate h3d file after solver run
•–nproc : Sets number processors for the solver run. Default = 1.
RADIOSS_PC
Points to the location of the RADIOSS solver launch script that is included with the HyperForm installation for the Windows platform.
RADIOSS_UNIX
Points to the location of the RADIOSS solver launch script that is included with the HyperForm installation for the Linux platform.
SymmetryTolerance
Specifies Tolerance to identify nodes that define constraints based on the symmetry plane definition in the User Process and Auto Process.
DistanceCalc
Specifies the method for distance calculation in the User process and Auto Process. Lets you specify two values: 1: Old method; 2: New method. Default value: 2.
Drawbeads
Option to turn On and Off the Drawbead editor from the Auto Process. Lets you specify two values: 1: Enabled; 0: Disabled. Default value: 1.
WindowGeometry
Applies default window geometry size and location: 640x520+0-30.
MSM_Autoposition
Enables or disables the Autoposition option in the Multistage manager. Lets you specify two values: 1: Enabled; 0: Disabled. Default value: 1.
DB_DoNotProjectLines
Does not to project the drawbead lines on the target tool. Lets you specify two values: 1: Enabled; 0: Disabled. Default value: 0.
AutopositionConfirm
Asks for confirmation before performing the Autoposition option in the User Process. Lets you specify two values: 0: No; 1: Yes. Default value: 1.
AutoprocessWindow
Displays Auto Process. Two display options are available: Panel or Window. Default: Panel.
MultistageWindow
Option to display Multistage manager process. Two display options are available: Panel or Window. Default: Panel.
UserProcessDirectory
Lets you specify the directory to store the User process templates. By default, the directory is empty.
expand-green-10ProcessDefault Tab
RADIOSS Incremental
These following options are supported for both RADIOSS Incremental and LS-DYNA Incremental user profiles.
ProcessDefault Option
RADIOSS Mode
Four different modes are available to execute the RADIOSS solver for speed and accuracy.
Binder Wrap Velocity
Applies velocity for binder wrap operation. Default: 2000.
Draw Velocity
Applies velocity for draw operation. Default: 5000.
Motion RampType
Specifies ramp type Trapezoidal or Sinusoidal for the velocity motion. Default: Trapezoidal.
Motion Type
Specifies a Velocity or Displacement motion type definition for the tools.
Material_radioss
Sets a default material in the material database for RADIOSS Incremental.
Integration Points
Lets you define a table of integration points  vs.  minimum thickness that is used to define an integration point for blank shell elements. Defaults: 3 integration points for thickness until 0.8.; 5 integration points for thickness higher than 0.8.
Friction
Specifies default friction value for contacts between tools and blank. Value = 0.125.
Animation Count
Sets a request for a number of animations. Value = 10
ASCII Output Period
Applies a default time interval for ASCII time history file output. Value = 0.1.
Default Force
Applies a force for load definition in tools. Value = 1000.
Tool Offset Factor
Offsets tools from the punch or die by the value of the thickness* tool offset factor. Used primarily in the Tool setup panel.
Radioss Memory
Sets the memory in MB for the RADIOSS Incremental solver. Default: 50000.
Radioss Contact Type
Applies a contact type between the tool and blank for the RADIOSS solver. Options include Type 21 or Type 7. Default: Type 21.
Adaptivity Level
Sets the adaptivity level for blank elements. Options are 1,2,3,4,5, and Default, where Default = 2.
Gravity Results
Provides options to Include or Exclude strain results in the STA file created after a gravity run. Default = Exclude.
